strange, indeed. Would you be willing to share the model so that we can take a look at it?
Jeff Strater (Fusion development)
No it was the default setting.
I just tested the same in my Laptop (PC) and it looks good.
Strange the problem occured in my Workstation (PC).
Could this be a graphic problem?
/Håkan
Hi there, I'm just very curious about your part. It looks like a distributor cap or pressure dome or maybe a Dalek head? 🙂 What is it?
Base with no whip? Looks interesting. Thanks 🙂
Hi Jeff!
Today I loaded the the part in the workstation again, the mesh was ok!
Strange....
/Håkan
Sorry I don't know what "whip" means.
This is just the cooling frame, inside it will be a butterfly antenna.
/Håkan
Hi, I got this problem again.
Saved and closed the object. Open and then made the mesh, then it was ok!
Sorry but I can't find out what type of graphic card, only some type of Intel card.
/Håkan
