Hi @Anonymous,
I want to add that when the subscription expires, you can no longer access your software or cloud services. Remember, the user with an expired subscription can still view and share projects using our free viewers.
The best solution in this case is to set up a Fusion Team Hub for the company/user group and transfer the ownership of the project to the Team Hub. Then, anyone who has access to the Project within the Team Hub, can access this data and it is no longer dependent on the original user.
Since someone else created the data, and own the data - but the data would now be stored in your Fusion Team storage. This way, if the original owner leaves your hub/company, the data still remains within your Team. In the event original owner leave the company/hub, he would not need to delete his account - but you can mark his access as "inactive" - meaning he is no longer a member of your Fusion Team hub. He "owns" the data created but would have no access to it.
So if the project has been moved to your Team Hub (where you are the owner of), it is no longer dependent on the original user.
