Search Error MESSAGE_NO_SUCH_OBJECT
SMI-CAD2
SMI-CAD2
This has been happening for a while,  I do a search in the data panel,  and it gives me this message.  As you can see I am searching for the file that is shown in the folder.
Is there a wild card symbol that I need to be using, . A lot of times I am not sure of the exact name name of the file,  even when I type in this exact name shown here, it comes up with hundreds of results,  this is very frustrating when trying to search for items that you may have created a long time ago.
 I have tried the manual reset by renaming the .dat files  (which is silly to have to do in the first place) and it does not do anything.
Rafal.Chlod
Autodesk Support
Autodesk Support
Hi @SMI-CAD2, thanks for posting.
If I'm assuming correctly, the error "There is no object with ID Community...", because after the project transfer, some files still indexed with the ID of the previous project, and now it is causing issues at the time to search.
So, if the project was transferred, as a workaround, I suggest is to move the folders/files affected to another project so the re-index should be triggered again. The re-index could take some hours but as a short-term fix, it should work.
If my answer helped you, please click Accept Solution. Thanks!
Rafał Chłód
Global Product Support
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
