Remote Fusion instance access (license question)
o.yefimov
Observer Observer
Message 1 of 8
o.yefimov
Observer
Observer
Dear Autodesk community
Could you please help me clarify a concern
Am I able to use a single license of Fusion 360 on Device A and access it through the RDP protocol from another device, Device B, in the morning, and then from a different device, Device C, in the evening?
Replies (7)
Message 2 of 8
brian.mark
@o.yefimov I'll see if I can find out for you, but you might have more luck asking in the Fusion Support forum.
Brian Mark
Sr. Product Owner-Fusion Team
Message 3 of 8
brian.mark
@o.yefimov You are fine using Fusion in the way you described. You are allowed to access from many devices, as long as it is not concurrent.
Brian Mark
Message 4 of 8
o.yefimov
Observer
Observer
Thank you
"I have another small extension to this question. Would I be violating the license if I have a server with a purchased license and access it via Remote Desktop Protocol (RDP) and I access it in the morning or in the evening, and another engineer accesses it at night (all accesses occur at different times, via RDP, with no parallel access)?
Message 5 of 8
o.yefimov
Observer
Observer
  • Thank you
Message 6 of 8
brian.mark
@o.yefimov While this would technically work, I can't confirm that it is against the Terms and Conditions as I am not with licensing or legal. The Autodesk general Terms and Conditions can be found here:
https://www.autodesk.com/company/terms-of-use/en/general-terms
Brian Mark
Message 7 of 8
o.yefimov
Observer
Observer
Thank you for your time. I have read all the terms and didn't find any violations, but I want to make sure everything is correct. Could you please redirect me to someone who can confirm if it's legal according to the license terms?
Message 8 of 8
brian.mark
@o.yefimov As this forum is for trouble shooting issues with Fusion Team, you may be better served by contacting support via this link (https://knowledge.autodesk.com/contact-support?utm_source=forum-siderail&utm_medium=webpage&utm_camp...) and contacting your own lawyer.
Brian Mark
