Only able to access fusion through hubs; unable to create/access any teams
zanebeeai
Observer Observer
zanebeeai
Observer
Observer
I'm unable to create a personal team through which I can create and edit personal projects. The only medium through which I'm currently able to access fusion is via a hub I created when I first made the account that is for a different (ongoing) collaborative purpose, but I would like to have a personal TEAM (not hub) wherein I can create and edit my own projects.
To be honest, had I known the difference when first installing fusion, I probably would have just made a team as opposed to a hub for that aforementioned project. Now I'm stuck with it (and don't want to delete anything associated with that initial hub as it is still in use), but I still want to use Fusion for other personal projects on this account, ideally not on that hub.
RajkumarIlanchelian
@zanebeeai @One account can be associated to only one team hub ( but you can be invited into any number of team hubs).
In your hub, you can create projects and have permissions only for you to access it and not anyone else. You can also add/remove permissions on other projects currently your hub as well.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
zanebeeai
Observer
Observer
I've seen someone else be able to have a personal "team" independent of "hubs". This would be a lot more convenient; is this possible? Can teams coexist at all with hubs?
RajkumarIlanchelian
@zanebeeai @Not any longer. When Fusion was first introduced everyone has a personal hub and not a team hub. You can no longer have personal hubs. Everything is a team hub irrespective e of if you collaborate or not.
Autodesk Fusion
Join Fusion Insider
zanebeeai
Observer
Observer
Got it, thanks for the response!
Cooperdesignbuild
Community Visitor
Community Visitor
I can't see other teams or creat my own hub on my new account
RajkumarIlanchelian
@Cooperdesignbuild Can you please direct message me the email used to register for Fusion.
Autodesk Fusion
Join Fusion Insider
