Need help - Modeling an AFO over a leg scan - T-spline conversion results in solid .stl file when I export to Netfabb
I am very new to this.. watched a 7 year old video (https://youtu.be/XT0p7tVqUfA?si=d78i0vAgx_3i8LeK) on how to model an AFO and got all the way to exporting the .stl however when Adding it to Netfabb to print the part, it comes through as a solid part.
I have attached the fusion file: https://a360.co/3IaeGYT
Note that I opened the Leg Scan .stl, went to Form, created a cylinder, sized accordingly, moved accordingly, selected Pull on the Body which produced the anatomical shape, then Edit Form to adjust the shape to sit just off the scan.
Thanking you in anticipation 🙂
