Need help - Modeling an AFO over a leg scan - T-spline conversion results in solid .stl file when I export to Netfabb
marlene77YYX
Observer Observer
marlene77YYX
Observer
Observer
I am very new to this.. watched a 7 year old video (https://youtu.be/XT0p7tVqUfA?si=d78i0vAgx_3i8LeK) on how to model an AFO and got all the way to exporting the .stl however when Adding it to Netfabb to print the part, it comes through as a solid part.
I have attached the fusion file:  https://a360.co/3IaeGYT
Note that I opened the Leg Scan .stl, went to Form, created a cylinder, sized accordingly, moved accordingly, selected Pull on the Body which produced the anatomical shape, then Edit Form to adjust the shape to sit just off the scan.
Thanking you in anticipation 🙂
hfcandrew
Can you attach the .stl?
marlene77YYX
Observer
Observer
Hi Andrew, here we go 🙂
marlene77YYX
Observer
Observer
Thank you Andrew, just worked it out.. have to Covert T-spline to Brep, then the new body 'Create Mesh' - the .stl file is perfect. Really appreciate you reaching out.  Take care, Marlene
hfcandrew
Yep that's it.
Your .stl is just a zero thickness surface. Not a 'watertight':
I design AFO's and orthotics and dental models directly in Meshmixer. You get much more control and accuracy.
