Hello, I just would like to suggest two things for the Design Reference section. There are "USES" and "USED IN" tabs, but they are all "사용". I feel that it may be better to distinguish them by "사용하는 설계" & "사용되는 설계" or "참조하는 설계" & "참조되는 설계" respectively. Therefore, I am suggesting:
"USES" : "사용하는 설계" or "참조하는 설계"
"USED IN": "사용되는 설계" or "사용되는 설계"
or simply "사용함" or "참조함" & "사용됨" or "사용됨".
Solved by Bud_Schroeder_ADESK. Go to Solution.
Thanks for posting your question to the forum, and I used Google to translate the post.
"Hello, I just would like to suggest two things for the Design Reference section. There are "USES" and "USED IN" tabs, but they are all "ON". I feel that it may be better to distinguish them by "using design" & "used design" or "referencing design" & "referenced design" respectively. Therefore, I am suggesting:
"USES": "Design to use" or "Reference to design"
"USED IN": "Design used" or "Design used"
Or simply "Enabled" or "Referenced" & "Enabled" or "Enabled"."
This is a great suggestion, can you post it to our Idea board. That is where we capture ideas on new features as well as enhancements on existing features. Once posted, others can add comments and vote on it. That will give us an idea of what people would like to see in future versions of A360.
A360 Idea board:
Thanks again for your feedback and looking forward to seeing this in the Idea board.
