Hey Guys,
I had previously assigned a contract to a Team hub and now I like to assign to same contract to a different hub. But now through the autodesk administrator account it is just showing my assigned contracts but it is not showing any option to assign the hub to another contract .
Is there a way to do that . Please see the below image.
Looking forward for your reply
Regards
Aadithya
Application Engineer
USAM CADSoft
Solved by asiteur. Go to Solution.
Hi @asiteur
Thanks for your reply
I do have another question . Actually I own a Fusion Team Hub and there are some of my colleagues whom I have added in the hub ... suppose if I resign I would like to transfer the ownership of the hub to another person . Now how can I do that ?
Regards
Aadithya
Hi there,
In case the hub administrator leaves the company you should do the following:
1) Go to Admin Settings > Members and Role and give someone else Administrator rights
2) Make the new admin remove your own rights and deactivate you as a Team Member
3) (Optional) access to the "Assign Contracts" area is provided to the Software Coordinator and Contract Manager roles, have this role changed by your reseller.
Clear enough?
