How to move a fixed object in sketch
Hi All,
I run into a problem: I have an object in the sketch, and this object can not be easily fully constrained (I copied its profile from a photograph). Now I need to paste this unconstrained sketch (but it must preserve dimensions), move and then add other common constraints for both objects.
Since the first unconstrained sketch is fixed, I can not move it and add constraints. If I unfix it, then even single common constraint breaks dimensions of the first sketch.
Is there a way to fix an object in the skecth to preserve its dimensions, but let it be movable?
Since I new to Fusion 360, I must be doing something wrong, so please help me. Many thanks.
MoshiurRashid
Hi @Anonymous
Thanks for posting. Here is a screencast video that I've prepared for you about moving your sketch.
CLICK HERE TO SEE THE SCREENCAST
Please Accept the solution if it is helpful.
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
Many thanks, thats worked 👍
