Fusion Team, Data, & Project Management
Need help managing your Fusion (formerly Fusion 360) Team Hub? Have questions about adding or removing team members, or permissions? Get help from the collaboration experts.
Feature request about Project Contributors and assets Folder
1 REPLY 1
jean-michel_legoff
110 Views, 1 Reply
With the new options of File and folder permissions, I was wondering if it could be possible to share the Assets Folder to "Project Contributors" and not only for "Team Member".
To prevent any of our user to create "Project", most of them are only "Project Contributors" and are assigned to their project by few TeamMembers.
But it should be convenient for them to use centralized shared datas saved in "Assets" folder.
Many Thanks
1 REPLY 1
1. In case of 'Folder Level' Project type, the authority to create new Project is decided by a checkbox against the user's name in the Admin panel. So even if you have a userA as Team Member, userA won't be able to create a new Folder Level project unless you give a tick against his name in Admin panel. Hence, you don't need to make your colleagues as Project Contributor just to prevent them from creating new Folder Level Projects.
2. Assets project folder is a special type project which is accessible only to Team Members who are more likely to be your colleagues , people from same company. It is not accessible to Project Contributors because they are typically your external partners like vendors whom you may not want to access your standard catalog kept in Assets project.
Abhinav Singh
Product Owner
Technology Administrators
