Fusion Team, Data, & Project Management
Need help managing your Fusion (formerly Fusion 360) Team Hub? Have questions about adding or removing team members, or permissions? Get help from the collaboration experts.
Edit with the changed account name in the project description.
5 REPLIES 5
HOZTO
358 Views, 5 Replies
I changed my Autodesk account name.
Then when I opened Fusion360 the changed name was displayed fine.
However, in the list of projects, it is displayed as the name before it was changed.
It's not a serious problem, but I ask because it bothers me.
5 REPLIES 5
abhinav_singh
in reply to: HOZTO
Hi, Can you pls confirm from where did you change your Adsk account name?
Also, to be sure, your concern is that the name didn't change in the blacked-out area that you have marked in your image?
Abhinav Singh
Product Owner
HOZTO
in reply to: abhinav_singh
Thanks for the comment.
I clicked on my profile button in the top right corner of the program.
Then I went into my Autodesk account and changed my name.
It would be nice if the part marked in black in the picture could be fixed to a changed name.
Rushikesh.kadam
in reply to: HOZTO
@HOZTO I may be wrong but I believe the text marked in black will be a team hub name and not the name of the user. @abhinav_singh please correct me if wrong.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
1. The name is not the user's name, but the name of the Fusion Team hub
2. There is a known issue regarding this - that it takes only the first even name given to the hub. So, for example, you created a Fusion Team with the name TeamA and then renamed it to TeamB, it will still keep showing TeamA at this particular location.
This doesn't break anything, but I agree it doesn't look nice, will see if our teams can take it up in near future.
Abhinav Singh
Product Owner
osmodion
in reply to: HOZTO
It's been two years - is there a way to fix this yet? A old, silly temp name is causing embarrassment in front of clients.
