Document limit reached, but cant see any editable document
I cant save my scretch file, because Fusion360 says that Ive reached maximum number of documents.
When I am clicking " my editable documents" I cant see any, only " Documents marked as editable will appear here"
How can I remove files from editable to save new files?
All files I have in my project are "read only"
RajkumarIlanchelian
@Anonymous This sounds like the exact discussion in here. Can you please see if the solution works for you?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
thanks ! yes, that command helps me, now i can see which file is editable and change it to read only.
