Can't make any documents editable.
VectorRoll
Message 1 of 26
VectorRoll
As the Title says. I can not change any of my Documents to Editable. It worked yesterday when I first learned of the changed and was trying it out. Now today it does not work. Yesterday I had left at least one maybe two as editable. Then I closed the program and turned off my computer. Now today those two I was working on are Red Only and the counter for how many I can have says 1 of 10. The 1 I think is the un-started un-saved document that appears open when you start up Fusion360. Every single one of my documents say Read Only and when I use the link to open and view just my Editable Documents it just sits there with the Refresh Icon spinning. Any idea as to why I can not change any of my documents to Editable now? Is something wrong on your end like with the servers that hold our documents, to which I can not change their status? Any help would be greatly appreciated. Thanks
  • bug
Replies (25)
Message 2 of 26
matt.pooley
Hi @VectorRoll ,
The symptoms you're seeing suggest some type of network or server issue, so we can work out what is happening, could you collect diagnostic log files from Fusion and share them here or with me at [email protected].
You can generate logs through the Help menu, under the option 'Support and Diagnostics -> Diagnostic Log Files'.
Matt Pooley
On Behalf of the Fusion Dev Team
Message 3 of 26
brotherdustautodesk
I'm having the same problem on a freshly-installed copy of F360. All documents are marked read-only. When I try to change to editable, the refresh icon in the upper-left just keeps spinning. Pretty sure it's not a network problem. I will send my logs to you, @matt.pooley
Message 4 of 26
dave.usa
Same exact problem as VectorRoll. Items made editable yesterday show as read only today but they still allow me to edit them. I am unable to turn any new items to editable or to turn the previous editable item back to read only. The editable option is not highlighted although the read only is highlighted.
Message 5 of 26
Same problem as @brotherdustautodesk, on a newly installed Fusion 360, Feb-04-2021. All Documents in "Editable Documents" list are "Read-Only" by default and unable to change them to "Editable".
Message 6 of 26
jjs-autodesk
While we're looking into this issue, would you mind trying something for us, please?
  1. In Fusion, go to the "File" menu pull down and go to "View > Show Text Commands" to display the text command input window.  That brings up an input window at the bottom of Fusion.  (If you see "Hide" instead, you are already showing this.)
  2. In that input window, look to the far bottom right side and ensure the selector is set to "Txt".
  3. In the "Type Text Commands Here" field at the bottom, type:
    DataPanel.Reload
    Then press "Enter".  If this command executes correctly you should see a message similar to "DataPanel URL : file:///c:/Users/.../data_view_rel.html" confirming that the reload executed.
After running that, does your issue get better or stay the same?
Thanks.
Joel Schultz
Principal Engineer
PDG-Simulation
Message 7 of 26
gmelantoni
You should be able to use this text command as a workaround while we deliver a fix: DataPanel.url /default
Please let us know if that helps.
Thanks.
Guillermo Melantoni
Senior Product Line Manager
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
Message 8 of 26
mieczotronix
Yes, that helps.
Message 9 of 26
spacegeek.2048
FYI I have the same problem, the text cmd suggested above fixed the issue.
Message 10 of 26
spacegeek.2048
However, I need to redo the text command on every restart of the program, or nothing shows as editable
Message 11 of 26
I was having problems that the refresh wouldn't stop refreshing and all my files were in there and all said read only. I typed in DataPanel.Reload like what was suggested above and now everything is right. Thanks again.
Message 12 of 26
robert.turpin85
I am also having this issue as well
Message 13 of 26
mieczotronix
A few days since last DataPanel.reload, it has just happened again.
Message 14 of 26
jlgrills3GPVH
Observer
Observer
I was able to resolve the issue by logging out completely, restarting Fusion, and logging back in. The number of files editable updated to 0/10
Message 15 of 26
jim.frankfort
I had the same issue folks are documenting above.  Even though the model was marked as read only, I was able to edit it.  That model was previously editable.  Decided to add this because it doesn't appear to be documented.  Waiting for the definitive fix......
Message 16 of 26
motorhobo
None of my documents are showing as editable in the file browser, although the display in the upper right says 4 of 10. So I have no way of knowing which documents are the 4 editable ones. Plus, the Text Commands field does not accept input - the cursor cannot be set in that field.
Logging out and back in fixed the Editable display in the data panel for now but I still can't enter text in the Text Commands field.
Message 17 of 26
motorhobo
Sorry - was trying to enter text in the display field above the text entry field, so ignore that comment about the Text Comment input field not working.
Message 18 of 26
wesley.cassar
Community Visitor
Community Visitor
I had the same problem, the text cmd suggested suggested in this thread fixed the issue.
Message 19 of 26
glandretti
I have an 'editable document' that shows up in the program but there is no corresponding document in the web storage. I have run the DataPanel.Reload several times. It fixed an earlier problem but not this. Any suggestions? Thx.
Message 20 of 26
 Still won’t work for me after using DataPanel.reload?
