Assembly file composed of linked components is now empty - reduced to V1
TJS01
Message 1 of 1
TJS01
EDIT - CRISIS AVERTED.  Another colleague had a backed up version from a couple years ago.
14 hours ago I had a file open - an assembly made up of mostly linked files.  This has remained unchanged since 11/2022.  I had it open to stage some screen shots for colleagues.  I did not save changes (intentionally).  I don't believe I closed fusion, and maybe not even the file when putting the laptop (PC) to "Sleep".
This morning I went to open that file on another machine and it is 100% empty and shows V1 and a date of 11/16/2022 (the last time I actually saved any changes).
I searched around for solutions and saw the F cache folder may contain a .F3D of what I have lost, but apparently, only the individual files appear there. - EDIT - after leaving the empty file open for a bit, I did see that populate in the F folder, however, the instance from last nights session does not exist - only files that make up the assembly.
Is there any hope of recovering this or am I faced with completely rebuilding?
Replies (0)
