03:58 AM
If you Review the warning it tells you a point used for projection is missing. Usually if you uncheck Show Points on the sketch palette the point will show yellow but doesn't seem to work with your sketch. What I did find is selecting and hold at the origin shows 2 points, selecting and deleting the second one in the list fixes the problem.
Mark
Mark Hughes
Owner, Hughes Tooling
Found that hiding the origin then rotating the view with Show Points off and the yellow point shows up. I guess having stacked point there made the visibility a problem.
Mark
Mark Hughes
Strange.
The note was "Point is MISSING", but after you DELETED a point - everything is fine!
However, thanks for your advice.
