What happened to automatic joint previews?
AJ5QLT7
AJ5QLT7
Before, if you went to assemble a joint, you click on the the first point, then the second point, and fusion would automatically play the joint type animation for a split second. This was really useful because then I'd know what type of joint it was right away without having to click into the other menu. Now when I assemble joints, nothing happens, and the only way for me to preview the motion is to manually click on the joint preview button. Is there a setting to turn this on/off, or was the feature removed in the new updates?
AJ5QLT7
I'm a dumb dumb....they disabled the automatic rigid animation. When doing a rigid joint, nothing happens, but if it's on any other type of joint, it will automatically show the joint type preview.
