Weird gizmo rotation behaviour
thedmtom
thedmtom
Hey, since the last update im getting this kind of behaviour (snapping, fliping or whatever i would call that) when navigating via the cube gizmo. 3D Mouse is okay (but i didnt learn to use it yet lol)
Anyone have any idea ?
jhackney1972
Users, viewing your YouTube video, will not be able to see your issue so I suggest you create a Screencast, or use some other application that actually records the screen.  External videos rarely help.  I certainly could not see what was happening much less get a hint as to any issue.
John Hackney, Retired
helfenj
The "3D Gizmo" you speak of is the ViewCube and I have seen it flip like this from time to time when it set to something other than the default view.
Right click the View Cube and select Reset Home and Reset Front and see if it improves.
Hope this helps.
John
thedmtom
here is a better capture. I have thought i fixed the issue but its still there.
thedmtom
I have out of nowhere stopped having this issue, until recently when i bought a full licence of fusion 360 and started encountering it AGAIN. It is infuriating, here is a new capture. https://youtu.be/gm3ga1DotbE
The suggested reset home etc. didnt help. it happens in basically every project.
