I am trying to work out the weight of a component. I have entered component properties and am seeing results given in code ie. mass = 2.452E+04 g. How i make sense of this to get an actual weight measurement
Solved by g-andresen. Go to Solution.
If you are not familiar with scientific notations you can disable them in the properties or set the limits.
However, the mass in kg is only possible if m is used in the document settings.
günther
