Hi
I need to use Fusion 360 on different computers in our company. It's always just 1 user at a time (me), logging in and out each time changing the computer is no problem.
- Can I use a single user license on different computers?
- If yes, how many computers?
Thanks, Mani
Solved by Rushikesh.kadam. Go to Solution.
Solved by seth.madore. Go to Solution.
Solved by daniel_lyall. Go to Solution.
Solved by g-andresen. Go to Solution.
Solved by davebYYPCU. Go to Solution.
If the Fusion account is still running on another system at startup, you can terminate this instance from the current computer.
günther
I use 1 pc 2 laptops and a mac on one account, it is just sign-in sign-out.
Fusion is legal to be installed on as many computers as you desire, you just can't run Fusion at the same time on multiple devices, using the same login info. There is a mechanism in place that allows you to suspend the session on a prior computer and resume work on the current PC/Mac.
@mgrauZ237M Fusion 360 license is assigned to an e-mail address and not to a specific PC. Once activated, it does need to be transferred to a new machine.
To be able to use the active license on another computer:
If my reply was helpful, please click the "Accept as Solution" button. This helps others get the answer more quickly! "Like" is always welcomed.
