Updated Failed
Updated Failed
blowhise
Updated Failed
blowhise
Hello
Just open Fusion and this message appears:
Tried to do the suggestions but nothing seems to work. Here is my log file
Thanks in advance
RajkumarIlanchelian
@blowhise Can you restart Fusion and try again, please? We had an intermittent problem which now is addressed.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
blowhise
Hello Rajkumar
Unfortunately still the same, at the moment there are a some commands that are not working or they are buggie. I'm going to unistall everything and try a fresh install (again) : (
RajkumarIlanchelian
@blowhise Not sure if you got this working but our team took a look at the logs and here are a couple of things suggested.
Can you go to C:\Users\USER ID\AppData\Local\Autodesk\webdeploy\meta\streamer\20201203143300\ and zip up this 20201203143300 folder fo us? Once you have it zipped up, you can delete this folder and re-start Fusion 360. We believe this should get you back on track.
Autodesk Fusion
Join Fusion Insider
blowhise
Hello Rajkumar,
So sorry for the late answer, here is the zip folder. I followed the instructions and the problem persist
RajkumarIlanchelian
@blowhise Thanks for share the folder. While we take a look at this couple of questions.
1. Did you try an uninstall/reinstall?
2. If yes can you tell me the Version of Fusion 360 you are currently on? (Help->About should be a 2.0.****)
Autodesk Fusion
Join Fusion Insider
