I am creating a layered project that I intend to cut on my laser cutter. I created one layer and then copied it into separate, unlinked components and then stacked them. Now I want to extrude a hole through just two layers, but when I do, the extrusion also shows up in all of the other components. I've attached a screen capture. In the picture, the top visible layer was created from a different sketch. The second layer down is the top-most of the copied components, the next one visible is the bottom-most of the copied components. I've hidden the intervening layers. Each component is 0.200" thick, so the selected extruded cut should go all the way through the top layer and stop half-way through the next layer. Rather than just cutting through the layers I've chosen, it mirrors the cut onto the other copied layers, even though they are ostensibly independent. This can be seen in the pocket on the lower layer, which shouldn't be there.
I've tried copying the layers two different ways. First, I created a new component, chose 'move/copy' and then copied the existing component into the new component. Second, I tried selecting the component, choosing 'copy' and then 'paste new'. In each case, I get a new component that the indicator in the browser says is independent, but insists on mirroring any extrusions or cuts made after the copy. All of the videos and other tutorials I've looked at seem to say that my workflow is the right one, so what am I missing?
