I just noticed if you're in the CAM workspace and select Export you only get the option to save as an f3d file, change to the model workspace and you get all the formats. Is that intended or a bug?
Also noticed there's been a bit of a fix to the export dialog so you can use the windows Save As dialog again. When you pick the icon to choose the folder you are now given the standard windows Save As dialog rather than the pick directory dialog. Thanks for fixing that.
Mark
Mark Hughes
Owner, Hughes Tooling
