I exported parts from another CAD software as step files. Fusion read those in ok. Units were in cm’s. Strange but ok, as measurement were correct. For example, the attached part large hole in the middle is reported as 2.22cm diameter. I generated DXFs by creating a sketch on a face and saving the sketch as DXF. Opening the DXF in Fusion 360, the middle hole is correctly reported as 22.20mm. I sent the DXFs to my manufacturer, who reported that AutoCAD 2023 says files are ten times too small (middle hole 2.22mm).
The manufacturer was able to fix the scaling, so production was not disturbed. I'd like to know if changing the document dimensions in the step file fixes the issue; in other words, are my step files safe for further development? What is a safe method to use step files in order to avoid dimension errors in general?
