Fusion Support
Unable to trim intersecting curves
2 REPLIES 2
379 Views, 2 Replies
Hi. I am whole new to this game. I am trying to sketch a Toyota logo, which is made out of intersecting ellipses. With a lot of trial and error I was able to trim the extra lines from the ellipses which had the same origin. But I don't for the life of me figure out how to do that when the origin is in the different point.
2 REPLIES 2
JDMather
JDMather
Your geometry is on different sketches.
If you want to use geometry from a previous sketch to trim geometry on a later sketch, then you must Project the geometry from earlier sketch into later sketch.
Examine the Attached file.
g-andresen
g-andresen
only elements that are located in the same sketch can be trimmed.
This can be achieved by projecting all entities into a sketch and disabling linking.
projecting elements into another sketchprojecting elements into another sketch
This way you can do the trimming in the active sketch.
günther
günther
