Announcements
Unable to stitch or patch to make solid model. Why is it not working?
I've tried patching, stitching, and body filling the face that's open, but I am unable to close the model.  There's also one edge that highlights as 'open' when stitching, but i'm unable to patch or close that area to seal the model and make it solid.  Any thoughts or assistance would be greatly appreciated!
dsouzasujay
Hi @Anonymous ,
There were two surfaces, which was not allowing the body to stitch.
Deleting, redefining new surfaces  and stitching them will create a BRep body
Delete the middle surface:
Delete the surface i have deleted and redefine a new surface:
Attached BRep model.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Thank you.  I am able to delete the middle surface, delete the surface on the curvy face, then make a patch.  When i try to patch the rectangular face, though, it makes a patch but still shows as yellow rather than gray.  How did you make the new surface so that it joins with the rest of the body.  Yours is nicely solid!
dsouzasujay
Hi @Anonymous ,
I used Patch, The Yellow face will not stop you to stitch.
Grey coloured face is normal surface, Yellow surface is Reverse of normal face.
If in case if you want to change the normals, You can use "Reverse Normal" to flip the surface.
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Thank you - this worked! I very much appreciate your responses and guidance.
