Attempting to follow this tutorial - https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Unable-to-merge-me...
Am unable, due to lack of `Mesh` tab in my preferences.
I'm trying to select a mesh to both repair, then reduce.
Thanks!
P.S. Image for awesomeness.
Solved by TheCADWhisperer. Go to Solution.
It appears that you have the top level of the assembly active rather than the model_0 component.
Furthermore the model_0 component is an external link...
Make the external component active - what do you see now?
The support page you linked appears to be out of date with the current version of Fusion...
BTW - I wouldn't expect much luck with the mesh that you have in your image.
