Unable to save assembly - Error: source asset simulation studies in document XYZ has not referenced the target asset SimGenerativeModelSubtype in document XYZ
on my latest project I reached the point there I am not able to save the assembly any longer - most of the time:
- Error (when trying to save): Source asset simulation studies in document XYZ has not referenced the target asset SimGenerativeModelSubtype in document XYZ
- It is just a regular CAD assembly, no simulation, design history is currently disabled
- The issue appeared after working with the file for several weeks on different PCs without any problems - I had the issue already 2 month ago but it disappeared completely over night for whatever reason.
- Sometimes (not found a way to replicate the conditions yet) I can save little modifications like one simple hole -save - another one - save and then I am back with the error message again
- Deleting every component, body and sketch and trying to save an empty assembly also does not work
- Same issue on 2 different machines
- Fusion generally is kept up to date.
- Re-installing Fusion did not help.
- Clearing local files did not help
- Re-naming / moving / copying the file did not help
- Recovery files are being saved (guess because its on my PC not cloud) but anything that needs cloud saving does seem to produce the error message
I hope there is some fix, I already spend 2 days trying to troubleshoot this. The posts in the forum that were having similar issues were not giving me any more ideas than what I already tried.
