Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Unable to render Ground Reflection (despite showing up in Render Preview)
6 REPLIES 6
WillHarrisProxy
390 Views, 6 Replies
I'm having trouble rendering ground reflections on one of my models.
Here is the file: https://a360.co/3LAtPD3
When in the render workspace, the reflection and shadow show up fine. Here is a screenshot of the render preview and the environment settings.
Now, once it is rendered, this is the image that I get. Notice that it has no ground shadow or reflection.
Here is a screenshot of my graphics diagnostic:
The reason I know it is not my computer is reflections work fine on another model.
Here is a screenshot of the other model in the render preview with the environment settings:
And the Graphics Diagnostic to show it is the same:
And the final render, showing that reflections work fine.
Troubleshooting I have tried:
Tried different Environments
toggled each setting in the environments panel
restarted Fusion 360
restarted my PC
Messed with in-canvas render settings
None of these had any effect.
Can you help me figure out why fusion won't render shadows and reflections for this model?
Thanks for your time!
Tags (1)
6 REPLIES 6
Can you share the model in question? (export as .f3d and attach to next post)
Sure! This is the same file I linked to above. (https://a360.co/3LAtPD3) but exported as an .f3d and attached.
With the file I downloaded I don't see the problem you describe:
In general it is better to create a your own ground plane and not rely on the built-in ground plane.
That offers much better control over all aspects of the ground material.
Thanks for the help and for giving it a shot. To confirm, did you try rendering the model, or just previewing the render? Because the problem is only visible in the processed render. It looks fine in my render preview as well. The problem occurs in the results of using this dialogue:
Also, I'm not familiar with creating my own ground plane. I searched for creating a ground plane, and all I could find is the checkboxes that I am using in the scene settings. How do you define a custom ground plane like you are advising?
Thanks for reporting!
I can reproduce the problem with the attached dataset in Local Render, and I've created a bug to track this internally FUS-107543. We'll investigate and let you know once we have more progress in addressing it.
Let me know if you have other questions.
-Lisa
@WillHarrisProxy I used the canvas render, but not the local render.
If you don't want to rely on the built-in ground plane you'll simply have to model a ground plane and assign an appearance material to the object.
