Unable to install Nastran solver because of a software update
D-NGK
D-NGK
since the last update I receive this message, when I want to do a local simulation.
I already tried to clean the cache, do a manual clean install and do a clean install with the fusion cleaner utility.
Nothing helped so far and in this forum.
Also none of the information I could find in this forum helped me so far.
Thanks for your help alrady!
Marcin_Kosciolek
Autodesk Support
Autodesk Support
Hi @D-NGK
The solution for this issue is to reinstall Fusion 360 manually. Please download Fusion from your Autodesk Account, and after that, run an installer. You don't need to perform a clean uninstall beforehand.
Marcin Kościółek
Global Product Support
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
D-NGK
I have done that already as described above.
Once with a mnual clean install described here
and one with a automatic clean install using the cleaner utility.
Both fresh installations had the same issue.
Marcin_Kosciolek
Autodesk Support
Autodesk Support
Tell me please, what version of Fusion you have after reinstall?
To check it in Fusion, click on the questioner in the right-top corner, and then click About.
Marcin Kościółek
D-NGK
The version is:
2.0.10811
Windows 10 (19043)
Marcin_Kosciolek
Autodesk Support
Autodesk Support
Hi @D-NGK
You don't have the latest version of Fusion (this is one of the versions which has troubles with Live Update). Fusion is not able to upgrade to the newest version, and it generates troubles with other environments (like Simulation). Please download one again installer from Autodesk Account, and install Fusion one more time. Versions higher than 2.0.10811 should be free of this issue.
Marcin Kościółek
D-NGK
@Marcin_Kosciolek thanks for the feedback. Now after giving it another try to reinstall it is working.
Thanks!
