Unable to install fusion on MAC
I have been unable to reinstall fusion on my MAC, running Sonoma. here is the log files.
Please help.
2024-02-22 09:31:32,658 - MainProcess(75683) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: /Users/marcfish/Library/Logs/autodesk.webdeploy.streamer.log
2024-02-22 09:31:32,659 - MainProcess(75683) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-02-22 09:31:32,659 - MainProcess(75683) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-02-22 09:31:32,659 - MainProcess(75683) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x10ad89d00> #
2024-02-22 09:31:32,659 - MainProcess(75683) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-02-22 09:31:32,659 - MainProcess(75683) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from /Users/marcfish/Library/Application Support/Autodesk/webdeploy/meta/streamer/20220719105500/resources/buildinfo.json
2024-02-22 09:31:32,660 - MainProcess(75683) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-02-22 09:31:32,660 - MainProcess(75683) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20220719105500
2024-02-22 09:31:32,677 - MainProcess(75683) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_GB
2024-02-22 09:31:32,677 - MainProcess(75683) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: /Users/marcfish/Library/Application Support/Autodesk/webdeploy/meta/streamer/20220719105500/resources
2024-02-22 09:31:32,678 - MainProcess(75683) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to /Users/marcfish/Library/Application Support/Autodesk/webdeploy/meta/streamer/20220719105500/certs.pem
2024-02-22 09:31:32,678 - MainProcess(75683) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-02-22 09:31:32,679 - MainProcess(75683) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-02-22 09:31:32,679 - MainProcess(75683) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-02-22 09:31:32,679 - MainProcess(75683) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function uninstall_process at 0x10ad915e0>, operation=<function multiple_operate at 0x10ade8dc0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection=None, update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-02-22 09:31:32,679 - MainProcess(75683) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-02-22 09:31:32,679 - MainProcess(75683) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-02-22 09:31:32,680 - MainProcess(75683) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-02-22 09:31:34,258 - MainProcess(75683) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Uninstall
2024-02-22 09:31:34,504 - MainProcess(75683) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-02-22 09:31:35,045 - MainProcess(75683) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host autodesk.com is accessible
2024-02-22 09:31:35,048 - MainProcess(75683) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: NTAuMTkuMTQ5LjQ=
2024-02-22 09:31:35,049 - MainProcess(75683) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTI3LjAuMC4x
2024-02-22 09:31:35,135 - MainProcess(75683) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: U2VydmVyOgkJODguMjE1LjYxLjI1NSwgQWRkcmVzczoJODguMjE1LjYxLjI1NSM1Mw==
2024-02-22 09:31:35,136 - MainProcess(75683) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-02-22 09:31:35,136 - MainProcess(75683) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
Traceback (most recent call last):
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 1159, in execute
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/uninstall_process.py", line 500, in execute_check
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 1447, in execute_check
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 534, in _init_registry
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process_utils.py", line 117, in newregistry
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/registry_root.py", line 52, in install_registry_root
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/registry_root.py", line 41, in _new_reg_root_helper
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/registry.py", line 569, in __init__
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/registry.py", line 149, in __init__
apsw.CorruptError: CorruptError: database disk image is malformed
2024-02-22 09:31:37,607 - MainProcess(75683) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-02-22 09:31:37,607 - MainProcess(75683) - InstallDriver - adsk.dls.streamer.process.process - WARNING :: Exception in Uninstall CorruptError: database disk image is malformed
2024-02-22 09:31:38,517 - MainProcess(75683) - InstallDriver - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2024-02-22 09:31:38,517 - MainProcess(75683) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2024-02-22 09:31:38,517 - MainProcess(75683) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # #
2024-02-22 09:31:38,518 - MainProcess(75683) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x10ad89d00> #
2024-02-22 09:31:38,518 - MainProcess(75683) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # #
2024-02-22 09:31:38,518 - MainProcess(75683) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-02-22 09:36:48,880 - MainProcess(76023) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: /Users/marcfish/Library/Logs/autodesk.webdeploy.streamer.log
2024-02-22 09:36:48,880 - MainProcess(76023) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-02-22 09:36:48,880 - MainProcess(76023) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-02-22 09:36:48,880 - MainProcess(76023) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x105f2c1d0> #
2024-02-22 09:36:48,880 - MainProcess(76023) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-02-22 09:36:48,880 - MainProcess(76023) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from /private/var/folders/sr/ptrysygx29v1fbs5z209kg7w0000gn/T/AppTranslocation/B4DA8595-AF57-41FA-A993-FFC435A3CD5D/d/Install Autodesk Fusion.app/Contents/MacOS/resources/buildinfo.json
2024-02-22 09:36:48,880 - MainProcess(76023) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-02-22 09:36:48,880 - MainProcess(76023) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20231212154431
2024-02-22 09:36:48,887 - MainProcess(76023) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_GB
2024-02-22 09:36:48,887 - MainProcess(76023) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: /private/var/folders/sr/ptrysygx29v1fbs5z209kg7w0000gn/T/AppTranslocation/B4DA8595-AF57-41FA-A993-FFC435A3CD5D/d/Install Autodesk Fusion.app/Contents/MacOS/resources
2024-02-22 09:36:48,887 - MainProcess(76023) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to /private/var/folders/sr/ptrysygx29v1fbs5z209kg7w0000gn/T/AppTranslocation/B4DA8595-AF57-41FA-A993-FFC435A3CD5D/d/Install Autodesk Fusion.app/Contents/MacOS/certs.pem
2024-02-22 09:36:48,887 - MainProcess(76023) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-02-22 09:36:48,888 - MainProcess(76023) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-02-22 09:36:48,888 - MainProcess(76023) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-02-22 09:36:48,888 - MainProcess(76023) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x105f12fc0>, operation=<function multiple_operate at 0x105527a60>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-02-22 09:36:48,888 - MainProcess(76023) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-02-22 09:36:48,888 - MainProcess(76023) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-02-22 09:36:48,888 - MainProcess(76023) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-02-22 09:36:48,888 - MainProcess(76023) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-02-22 09:36:49,999 - MainProcess(76023) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-02-22 09:36:50,027 - MainProcess(76023) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-02-22 09:36:50,530 - MainProcess(76023) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host autodesk.com is accessible
2024-02-22 09:36:50,532 - MainProcess(76023) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: NTAuMTkuMTQ5LjQ=
2024-02-22 09:36:50,533 - MainProcess(76023) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xLjE1
2024-02-22 09:36:50,576 - MainProcess(76023) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: U2VydmVyOgkJODguMjE1LjYxLjI1NSwgQWRkcmVzczoJODguMjE1LjYxLjI1NSM1Mw==
2024-02-22 09:36:50,576 - MainProcess(76023) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-02-22 09:36:50,577 - MainProcess(76023) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 1185, in execute
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 1503, in execute_check
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 543, in _init_registry
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/registry.py", line 150, in __init__
File "src/cursor.c", line 240, in resetcursor
