If I use a component and insert it into an assembly, I am unable to show/hide componts within the assembly for files that are “inserted” into the assembly. I have to open the original file and hide/show components, sketches, bodies, construction geometry, etc. in order to make them hide/show in the external assembly file. Super cumbersome and inefficient.
You should be able to hide/show components in linked assemblies, but not sketches, construction geometry etc.
Anyway, the many disadvantages of working with too many linked components are a good reason to re-evaluate if these are really necessary.
I did not say that it is unreasonable 😉 That applies more to the limitations in Fusion 360.
Also I was not aware that you are alike about the CAM environment.the behavior there might be different. I cannot comment on that a I don't work in CAM environment.
Hi, thanks for posting.
There are currently a few limits on what can be toggled on and off, but I am unaware of any problems with component visibility in CAM, inside xref components. Are you talking only about body and sketch visibility?
This is something we plan to change, so thanks for posting and adding your feedback.
