I have been trying to create a curve for the longest. i thought i was close but now i get a error message when i try to "finish form". Can anyone take a look at my model and figure what i am doing wrong?
Solved by TrippyLighting. Go to Solution.
Yep, almost everything. You start with importing crappy vector graphics geometry into a sketch.
Instead of using the solid model an surface tools you use a T-Spline / Form with creasing and then fill the sides with "something" I have yet to figure out.
Here's a quick fix that should help you move along. My recommendation would be to watch the tutorials in Learn & Support section.
Peter thank you for figuring out for me. I didn't even realize there were surface tools.
