Fusion Support
Unable to drag sketch objects
1 REPLY 1
eerier_bleach0f
77 Views, 1 Reply
eerier_bleach0f
I can drag sketch objects no problem AS LONG AS I don't click and drag this line:
If any other line segment gets selected and dragged it works as expected. But that line? Nope. Been an issue for years on pretty much every sketch I've created where I need to move something with my mouse cursor.
Autodesk's most dedicated bug reporter: https://forums.autodesk.com/t5/user/viewprofilepage/user-id/15188348
1 REPLY 1
jhackney1972
You will need to attach you problem model so the Forum users can take a look.  A video may show the symptoms but the file contains the cause.
If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
