Hello , I have a model and I was thinking to 3d print it . I clicked to download autodesk print studio but it does not responds . I have ANET 3D printer . Help me out. Or can I use different print studio , I am new to 3d printing .
Solved by kate.raskauskas. Go to Solution.
Hi @sanket223.patil,
Print Studio isn't supported for Fusion 360 anymore. If you want, you can download it and install it manually from here, or you can take a look at other apps available for Fusion 360 in the Autodesk app store.
OK , Thanks .
Can you tell me which app shall I use . I am new to 3D printing .
I would go over to the Design forum and ask there - there are a lot of other users who do 3D printing and can give you advice based on your situation
The latest version of Fusion 360 shows a button to "Download Print Studio" when clicking the Make/3D Print option. If Print Studio is no longer supported, remove the button and replace it with instructions of how to manually install it or other recommendation.
I would second this (rather older now) suggestion. Why is Print Studio still in there if it is not supported officially?
It is even a bit smile-inducing that selecting "Print Studio" shows a message that it is not supported and to select something else....which mean specific coding was done to put that message in there, but not just to remove that option 🙂
Nick Kloski
