Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
turn off dragable components
2 REPLIES 2
jonas.haardoerfer
266 Views, 2 Replies
Hi there,
I am currently designing a thing (wow) in Fusion360 and I noticed that you can drag components freely troughout your designspace. How can I turn this feature off because I think this is quite annoying (currently working with a trackpad, often accidentaly dragging components) ?
Thanks in advance!
Tags (2)
2 REPLIES 2
You can turn off Component Drag using the check box shown below.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Did my post answer your Forum question?  If so not forget to mark the Forum post, that solved your question, by selecting the "Accept Solution" icon. This closes the question, makes the solution available to others with similar questions and acknowledges the solution as helpful. If it did not answer your question please post any further questions you have.
John Hackney
Retired
