Trying to export .DXF file without bend lines for lasercutting
kariD9GSU
kariD9GSU
I am working with a sheet metal flat pattern and want to export to .dxf for laser cutting but the bend lines keep showing up in the .dxf file even though I "turn off" the bend lines.
how can i avoid this?  what am i missing? thx!
HughesTooling
From within the flat pattern workspace, create a sketch and project the face then Save As DXF from right click on the sketch.. If you have auto project enabled just creating the sketch will project the face so don't project again or you'll end up with double lines.
Mark
Mark Hughes
Owner, Hughes Tooling
kariD9GSU
perfect, this works!  thank you
