Trouble Converting Mesh to Organic Solid
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am attempting to convert a surface mesh (STL) to a solid body using the Organic option. The option failed and recommended to use the "Create Base Feature" option, however I do not see the option. I checked for it under the Design>Create menu. I also tried repairing the design surface mesh, however the repair tool either removed the entire mesh, or removed parts of the mesh depending on the setting used. The STL file is quite large which may be part of the issue. Please let me know if you can help.
