Trouble Converting Mesh to Organic Solid
wernickar
Observer Observer
wernickar
Observer
Observer
I am attempting to convert a surface mesh (STL) to a solid body using the Organic option. The option failed and recommended to use the "Create Base Feature" option, however I do not see the option. I checked for it under the Design>Create menu. I also tried repairing the design surface mesh, however the repair tool either removed the entire mesh, or removed parts of the mesh depending on the setting used. The STL file is quite large which may be part of the issue. Please let me know if you can help.
jhackney1972
Please attach your STL file.
John Hackney, Retired
wernickar
Observer
Observer
I cannot attach it since the geometry is proprietary.
TrippyLighting
Based on the complete lack of information you have provided so far, we cannot provide any meaningful help.
Warmingup1953
This where it is for me:base.jpg
TheCADWhisperer
@wernickar
Can you Attach a dummy file that exhibits the same behavior as your proprietary data?
wernickar
Observer
Observer
The Create Base Mesh Feature is not there in my software. Is it part of an extension?
Also, I am working on seeing if there is a geometry that I am allowed to send that is having the same issues.
