I've made a design for 3d printing and need to export the individual bodies to STL's. When I hit "save to stl" in the root of the component browser, i can export the design to one whole stl successfully.
However, if I export with the "one file per body" option, the process fails with the following warning:
Error: Autodesk Translation Services failed to translate the current document to stl file!
[... one error per attempted exported file]
Error: STL Translator failed to export data
Again, if I dive into the components tree and try to export one of the bodies individually, (e.g. not trying to do a batch export, but exporting all bodies individually) the process fails again with the same error message as above.
I have never had similar issues. I'm on a mac running High Sierra 10.13.5 and Fusion 360 Ultimate v.
2.0.4343
No features are throwing errors or warnings.
The images below show what doesn't work, and what works.
Any clue what may be wrong?
Thanks!
