- Mute
- Permalink
- Report
Hello.
I have been routinely using a 2D contour with ramp and tabs to finish the outside of parts. On this particular part, I can't make it work. If tabs are disabled, the ramp works correctly according to the inputs. If I enable tabs, especially triangular tabs, the ramp toolpath goes totally off the rails, cuts air for a bunch of passes, then plunges right to final depth and cuts through where the tabs should be. I have attached the .f3z file.
Any help greatly appreciated !
Brent
Link copied
