Fusion Support
Toolpath depth not accurate for a face that was moved with Press Pull
2 REPLIES 2
MattPerez314
248 Views, 2 Replies
I noticed recently that when creating a toolpath such as an adaptive clearing based on a face/pocket selection, that if the model was modified by press pull, that the toolpath depth would be based on its original location, not the selected face location.  The temporary fix was to change the depth type to "Selection" and manual select it, but this seems like a bug.
2 REPLIES 2
Have you got a sample file you can share? I guess this is a 3d adaptive not 2d, did you have flat area detect enabled?
Mark
Mark Hughes
Owner, Hughes Tooling
Hey Mark.  I tried to make a sample file because i couldn't share what i was working on..... It isn't behaving the same.  So I went back to the original file.....and it didn't behave the same either.  Not sure if something with the update that was just pushed maybe fixed it.  I will keep trying to see if i can make a file the behaves this way, but it seems to be sorted?
Thanks for the reply!
