Howdy,
I've been working in the drawings workspace, and I keep experiencing this one crash.
A percentage of the time that I add text, highlight the text, and change the font size, It'll freeze. There's no interacting with anything in the window, I can't close it or minimize it even. I've left this open for more than an hour before, so I'm going to call it a crash, because the only way I can resume work is to force quit the program.
I don't know if something exactly triggers it, but I would like to know if anyone has experienced this same issue. Its a bit annoying since the last thing I do in my workflow is to add text labeling dimensioned views of components. I'll usually loose a page off my drawings each time this happens.
Solved by Phil.E. Go to Solution.
HI,
Thanks for letting us know.
I found one of your older crash reports and noticed that the graphics drivers are a little bit older, from September 2021.
I can't say that will fix the problem, but at this point I wouldn't rule it out. Here is a knowledge article about it:
How to update graphics drivers for Fusion 360 in Windows.
If you can repeat one of these crashes with a particular set of steps, that might help me repeat the crash. In order to fix crashes or bugs we have to repeat them during a debugging process. Any help you can give is appreciated.
Appreciate it!
I'll update those and see if that fixes it.
I'll also see if I can make some time and figure out step-by-step what exactly causes this.
Thanks!
