I've been stuck in this temporary outage for the past 2 days and none of my projects are loading. I can't send report either. Please rectify my issue. (I'm using Fusion 360 in Windows)
Solved by RajkumarIlanchelian. Go to Solution.
@pranavadhi005 Can you please do the below?
1. Go to add/remove programs
2. Select Fusion
3. Modify
This will launch the Fusion service utility.
4. Run the gather system info - this will generate two zip files. Please attach the diagnostics logs.zip here
5. Now run the Reset Fusion
Does this help?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
I'm attaching the diagnostic zip files with this post, sir. It worked for me and now I'm not facing any issues. Thank you for your kind response!
