Swiping issue
Swiping issue
vs3ddruck
Observer Observer
Swiping issue
vs3ddruck
Observer
Observer
Hi Support,
I've created a path and a profile but Fusion ignores the path twice:
1. It don't swipes the full path.. even if its fully marked
2. It don't follows exactly the path... there is an additional circle
BR Viktor
TrippyLighting
Here is a much easier way to do this.
The coil tool also allows you to create spirals.
Instead of using a sketch for sweeping the profile, I use the edge of a surface.
If you go through the timeline step-by-step, the workflow should become clear.
At the very least, you should fully define (constrain and dimension) your sketches.
vs3ddruck
Observer
Observer
Hi TrippyLighting,
thank you very much.
The coil is much easer for my purpose.
Somehow the final swipe is working this way as expected.
