SVG file insert
SVG file insert
matt.jabloner
SVG file insert
matt.jabloner
I am trying to insert a customer provided SVG file into Fusion 360.  It comes into Fusion but is a mess. The fonts are positioned on top of each other and their relative sizes are incorrect. The graphic parts of the file are similiarly a jumble and there are extra graphic components not in the original.
I would so much appreciate any help/ideas you could provide.
Thank you,
Matty
jhackney1972
You did not attach your SVG file.
John Hackney, Retired
matt.jabloner
Sorry, needed to get customer concurrence which I did last night.  SVG file attached.  Thank you so much for any help/ideas.
g-andresen
The SVG showed a (seemingly) correct appearance for me only in Gravit Designer.
I attach the exported SVG.
But there are still some gaps to be closed in Fusion.
Screencast
günther
matt.jabloner
Thank you so much Guenther! I can work with the file now. Is the issue that not all vectors were connected?
Thank you again!
Matt
g-andresen
The Fusion Import shows a chaotic collection of elements.
In Inkscape you can see that it is an SVG for graphical purposes (e.g. a poster).
For example, there are elements that represent a shadow.
günther
