I noticed that after a recent update (not the very latest...."new" behavior started some weeks ago...) that my internal toolpath is hidden by what looks like the stock that you typically see when running the simulation. "Normally/before update" I would see the internal toolpath with the part profile being a blue and the stock a transparent yellow, like it is sliced open to get you the 2D cross-section. Now I see this green stock material and it hides the path. Any others have this issue?
Paul
Solved by seth.madore. Go to Solution.
This is your "In-Process Stock" display. I agree, for lathe work it's not really well implemented. You can do to things; turn off display or set it to transparent. Both options are available here:
Sweet....glad it was an easy one. For what it's worth, "transparent" is not transparent enough to make much out....but turning it off is what I am looking for in this case.
Thanks much
Paul
