Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Steps to remove material of a desired design?
4 REPLIES 4
litodrums
586 Views, 4 Replies
Hello I am working on an object that will be CNC machined. I want to create on the top surface indentation of a specific shape. I am enclosing the file with 30 shapes typical which I want to delete and leave in indentation.
Am I proceeding correctly or is this not the correct way to achieve this effect?
thank you for your time
4 REPLIES 4
jhackney1972
in reply to: litodrums
I want to be sure, is this what you are looking for?  Model attached.
John Hackney, Retired
litodrums
in reply to: jhackney1972
Hello and yes this is what I want to accomplish. I'm not sure of the steps involved.
thank you
jhackney1972
It was only one command.  Open the Combine command, select the base body as the first pick and then left click drag from left to right to form a window around all of your discs.  Select Remove for the operation and your got it.
litodrums
Thank you very much John I appreciate it very much.
Michael
