Hi there,
I was trying export model as .stp with decals or .dxf and its not working.
I need decals in right position and my manufacturer can open only .stp file.
Is there any solution how to do it?
Solved by innovatenate. Go to Solution.
To my best understanding, decals aren't support in the STEP file format. Have you consider making an engineering print (drawing) with dimensioned locations for the decal to show the supplier where the decal should be? You can also share a public link with the supplier like the one below. The share link will support viewing of the decal on the 3D model.
Does that help?
