Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Standard Hole Template
0 REPLIES 0
Message 1 of 1
96flintj
128 Views, 0 Replies
I have a countersink hole configuration that I use often.  When I go to add the hole I have to edit all my parameters (Angle, diameter, etc) to have the correct configuration.  Is there a way to save the configuration so I can click on the point that I want a hole and my configuration will be retained or is there a way to select my hole configuration from a drop-down or something?  I have to think there would be a way.  Thanks!
Tags (2)
0 REPLIES 0
